- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
Guess whats arrived back in our warehouse after being out of stock for so long.
Logitech G27 Racing Wheel - PC / PS2 / PS3 (941-000047) @ £199.99 inc VAT
A simulator-grade racing wheel, the Logitech G27 Racing Wheel is designed to deliver the definitive sim racing experience for the PC and Playstation 3. Its powerful, dual-motor force feedback mechanism with helical gearing smoothly and accurately simulates traction loss, weight shift and road feel, with exceptionally quiet steering action. The six-speed shifter with push-down reverse gear allows you to quickly choose exactly the right gear. New RPM/shift indicator LEDs let you know when you should shift gears; the 28-cm leather-wrapped rim provides hours of comfortable, true-to-life racing; and steel accelerator, brake and clutch pedals deliver precise control for heightened realism.
- Dual-motor force feedback mechanism with helical gearing
- RPM/shift indicator
- Sixteen programmable buttons plus D-Pad
- 900 degree wheel rotation
- Ultra-precise optical encoding
- Carpet Grip System
- 6 Speed Gear Shifter
- Steel gas, brake and clutch pedal
- Steel ball bearings
- Works with PC, PS2, PS3
Only £199.99 inc VAT.
ORDER NOW
ORDER NOW
