Compression look better and aren't to expensive..
Have you ever heard of "Bitspower"![]()
Yeah, that's why I said aren't to expensive..![]()
Whadafu?!?!?!?
Bitspower and inexpensive are to ends of a spectrum![]()
Cool, I'm getting compression, because it sounds more tight..
I thought Bitspower did the whole expensive quick release fittings etc
When I said aren't to expensive (compared to barbs) I was referring to xspc compressions fittings..
Either way, I was making Bitspower out to be expensive I'm not sure if you've read me wrong.
Hoseclips are not optional with barbs...
Hoseclips are not optional with barbs...![]()
Didn't use any clips on my barbs in my last watercooled build?
Use 1/2" barbs with 7/16" tubing and you're good to go.
bitspower compressions or go home imo![]()
