please dont say its true
16 Sep 2012
hi guys back for some needed help i bought a i5 2500k asus p8h67-m le mobo and 4gb kingston hyper x ram bundle kit but i have read somewhere that the h67 chip mobos cant be overclocked is this true i just wanted to get this at 4.4ghz
I am afraid that it is true - see extract below from a review of your board
Much like the situation with the outgoing i3/i5/i7 family, you will need to purchase a "H" series motherboard for Integrated Graphics support. Sadly a few of you might be left with a bit of a predicament. To be precise, the H67 chipset does not support processor overclocking at all. Yes, even if you purchase a "K" series processor with a H67 motherboard you are out of luck
Could you return the board under DSR ? Change to a P67 /Z68/Z77 board?
BTW welcome to the forums:)
thanks for the fast reply AgedIdiot i will just bin the board,ok would like to know what type of mobo YOU would get keeping in mind i want to keep the kingston hyper-x would like a mobo under £200 ,i havent got a clue what mobo i need for overclocking i did though get my q9550 stable at 4.6ghz on a asus p5q se2 mobo n arctic cooler pro v2 so im kinda hoping you guys /you may be able to help me choose a decent board /would consider changing the ram to a 8gb kit but would need help making sure the ram is compatible as well
Don't just bin the board, stick it on ebay or gumtree. At least you'll get something back for it.
YOUR BASKET
1 x ASRock Z77 Extreme4 Intel Z77 (Socket 1155) DDR3 Motherboard £104.99
Total : £114.89 (includes shipping : £8.25).
I would hope that you can get a more than decent clocking board and retain use of your ram - I assume it's the 1600mhz type?
I recently upgraded to windows 7 ultimate and at the same time upped board and ram but retained my cpu - a i2700K.
In upgrading a few problems occurred e.g managed to break one (secondhand but still cost £80) motherboard (got a bit impaitent), fitted a faulty cpu cooler (sealed watercooling unit which sounded like a bag of nails) etc
and in the end decided to go with an Asus Sabertooth Z77 board.
Expensive but easy to set up and overclock with - am currently running @ 4.3 with max volts less than 1.3 and do expect to get to at least 4.5 without having to increase voltages at all or by a miniscule amount.
I do not feel comfortable recommending the board simply because of the cost and from what I've read there are other boards which are as good but cost a fair bit less BUT I would not hesitate to buy again.:D
stobbsie - You NEED to remove your link to Ama..... - No links to competitors are allowed in any circumstances !!!!
There are loads of boards out there - take your time in choosing.:)
It is supposed to be fun :D
If you want to be sure your ram works with a particular board 'happily' , check here - someone may have the exact combo you wish to put in place - and /or check motherboard/memory makers web sites . ( You do get mis-matches occasionally - often for no real accountable reason)
BTW I have nothing against the Asrock board - the make has a good rep.
aged idiot just googled that board and found it http://www.overclockers.co.uk/showproduct.php?prodid=MB-512-AS&groupid=701&catid=5&subcat= if so it looks like it has a plastic cover over the board ,,dou you remove this ???? may be a dumb question just never seen anything like it ,other than that looks great
IM SOLD GETTING THIS BOARD THANKS AGEDIDIOT
The way it looked and the 5 yr warranty are what sold it to me :) (Sad in so many ways - and I'm not talking about the 5 yr warranty)
It looks a bit intimidating but if you do a google there are a few videos out there unboxing and setting up. I found one done by Asus very useful.
There is a thread on here about the board :-
http://forums.overclockers.co.uk/showthread.php?t=18401772
The plastic cover is their thermal armor, they use a small fan to push air around it to keep things cool
There are 2 such fans - both of which are classed , by me anyway, as noisy little b...
But per some reviews it is very debatable if either/both are needed.
Did find a way of calming things down so now have both running :) ; although for the 2/3 weeks I ran without one - no problem at all!
You can replace them with quieter fans 40mm IIRC.
