helppp!!
Try another plug, or if the psu is making a weird noise then i would blame that
the PSU is making the noice anymore the pc wont turn on at all ive took the cables out and put them back in 3 times now im sure something is broke could it be anything else maybe the motherboard?
The PSU is plugged into the MB right, as well as the CPU (should be a separate plug on the MB near the CPU)?
Can you post a photo?
ive just took everything out of the case i got told to try build out the case still no luck, ive even tryed with no ram installed to see if it even beeps but no luck, its the CPU, motherboard or the PSU im thinking the PSU because it makes a wierd noise like its hissing for around 5 seconds when i turn it on.
ive just also noticed something when i turn my psu on at the wall it makes a sizzling noice and it also does it when i press the switch.
Hmm, hears sizzling noise, doesn't realise PSU could be burnt out or faulty..
Also, dude fix your spelling up..
I'm not saying that, it's a simple task to do, maybe if you're a little younger than me I would understand, (I'm 12).
Lol, no worries, I think it's horrendous how some people that are older than me can't spell.
I think it's horrendous that you feel the need to make such a song and dance about it. Is it really critical that everybody can spell impeccably? No. Didn't think so.
I think it's horrendous that you apparently have no respect or manners. How the OP chooses to convey dialogue on an informal discussion board is entirely up to him.
OP, the best thing to do is to ring OcUK tomorrow and they should be able to give you some technical advice or if applicable start the RMA process.
It's not compulsory, it's just a bit weird how you can probably spell writing on paper, but not on the internet you know?
How do you know that i am older then you? I could be younger for all you know so just shut up and go away all i'm asking for is help and your criticising me about my spelling have you got nothing else to do matey? go get a life please. :D
