Absolutely no need for the pro features, but as you say its cheaper so yeah might as well grab that. Not that I can get the microsoft store to work at the moment..
Mind you, if I buy the upgrade will it give me a full ISO for future installs?
the install dvd contents are stored on drive c: and can be re-burned. Sadly I can't remember in which directory. With luck someone else will.
Think you mean ESD folder.
is there any way of removing apps from the your apps section that you don't want any more?
I have a Valid Vista Home Key but it won't install, just needs to be reactivated (for this laptop) by MS. They've confirmed its a valid key though. Do I need to install Vista to do the W8 upgrade? Its currently on the Developer Release of 8.
You mean on Metro ie Tiles?..right click on the Tile either uninstall or select unpin from start(both options appear at bottom after right click).
Really? I'm running it on an ssd and am far from impressed with the boot time.I have a new laptop with Windows 8 and the only thing good about it is the fast boot time.
So I will be binning the hard drive and installing Windows 7 on an SSD.
Sorry Windows 8 you do not impress me at all.
