- 29 Dec 2004
- Shepley
It's a tricky case. The driver says that he opened the door a bit to see if anyone was coming, but presumably he had to do that because the tints on his windows were so dark that he couldn't see. If he did only open it a little but hit the cyclist then the cyclist was too close to the car although the onus is on the driver to open the door safely.
Then the bus driver should have left sufficient room to stop but obviously didn't. It's just a culmination of small errors by all parties that end tragically, similar incidents probably occur countless times in London every day without anyone being killed.
