****Images of Items or Services Purchased in December 2012****
I had two pairs of those headphones fall apart on me, they are amazing but the build quality isn't great. I ended up returning them for a full refund.
Amazing headphones though for the price.
For a fiver can't go wrong.
SoundMagic E10, really happy apart from the fact I can't get a decent seal from the buds they give you so I've ordered some foam tips.
These are great earphones, I had mine for about 4 or so months now connected to a Fllo E6 AMP for my SGS2.
Sound great, but the sound is a little muffered at top volume, but am happy enough for their price!
These came yesterday:
These are cool, where you get them from?
Also have those E10s and I am on my third pair! Both times it was the bit of rubber around the cable that meets the jack you plug into the phone in my case. It just broke and then one headphone decided to stop working. Think the problem is that as it is a straight connection when my phone is in my pocket and I sit down with it plugged it there is a lot of pressure applied to it as it bends.
Don't get how you guys are breaking these so easy, mine's good as new.
Superdry is best as they do long arms! Woohooo!
*reuploading pic
Only real problem I found with Superdry is that their arms are long and nice but they make them thin on almost all but the bigger wintery coats/tops!
Surprised this turned up today from China, fully expected a January delivery given the usual Christmas delays of stuff shipping from there.
Note 2 dock.
I need some of that for cleaning my oven, then. Post me some of your offcuts you big hirsuit man, you.
Unfortunately I used it all for OcUK Secret Santa.
However, I can instead offer you some of my chest hair. It's nowhere near as coarse but perhaps you could use it to make a wig for one of your films. I'd expect it to be featured in the credits though.
I had a pair and the sound was good for the price but the build quality isn't that great.
The black plastic that houses the driver and the bud, is glued to the metal canisters using very weak rubber like glue. I know this because the black plastic seperated from the canister, was easy enough to glue back in with some Loctite gel glue but certainly an issue.
I will keep them in their pouch and try to be kind to them, they seem solid enough to me. That said every pair of in ears I have owned have had the rubber bit break/split where the wire goes into the cannister so we'll see!
