Flame, I rather like those. Price?
Hey they were £32.99 so pretty impressed
Not sure why, but I think I just fancied recapturing some pleasant childhood memories.
SoundMagic E10, really happy apart from the fact I can't get a decent seal from the buds they give you so I've ordered some foam tips.
These came yesterday:
Used to collect these religiously when was growing up.
How much did that come to?
A cool £18,000.
Also have those E10s and I am on my third pair! Both times it was the bit of rubber around the cable that meets the jack you plug into the phone in my case. It just broke and then one headphone decided to stop working. Think the problem is that as it is a straight connection when my phone is in my pocket and I sit down with it plugged it there is a lot of pressure applied to it as it bends.
Are they your arms? If they are then have you shaved them?![]()
Superdry is best as they do long arms! Woohooo!
*reuploading pic
Not mine, although mine are equally hairless. Sorry.
Tbh, I only find this strange because i'm like a yeti.
My back hair grows like wire wool. Pictures later.
BFM 3D
I need some of that for cleaning my oven, then. Post me some of your offcuts you big hirsuit man, you.
I had a pair and the sound was good for the price but the build quality isn't that great.
The black plastic that houses the driver and the bud, is glued to the metal canisters using very weak rubber like glue. I know this because the black plastic seperated from the canister, was easy enough to glue back in with some Loctite gel glue but certainly an issue.
I had two pairs of those headphones fall apart on me, they are amazing but the build quality isn't great. I ended up returning them for a full refund.
Amazing headphones though for the price.
