Itunes on another hard drive
Caporegime
9 May 2005
Cambridge
Using windows:
I have all my music on my F drive. I imported all that music when I set up itunes. Every now and then when I added a cd to itunes I forgot to link it to my F drive.
So I have been installing media to my ssd which I don't want to fill with music. I've now set itunes to rip cd's into my f drive but how do I move the ones I have already done?
Even though I clicked copy files over they are not on my f drive. So If I delete the music folder from my c drive the links no longer work.
Any ideas how I fix this without starting again with the files I mistakenly ripped to the C drive?
Thanks for that, like a numpty my problem was not being able to find File and organise library. I had to unhide the menu bar, doh!
Thanks again :)
Right tried it and consolidated the files which transfers over to my f drive From c drive. When I look though lots of my apps are missing from mobile data in comparison to the file still on my c drive.
One of those apps is avhd player. So I'm reluctant to delete the iTunes folder in case I lose this program as its been removed from iTunes.
I'm half tempted to wipe iTunes and start again but would i lose these apps?
I've not used avhd player so not sure but - if you downloaded them via an iPhone or iPad, you can just re-download them via your purchased section (in app store) and it should re-sync to the new itunes lib when you connect the device.
Worth a try, just back up the old files incase.
Cheers, when you back up itunes to another drive before wiping etc I take it the folder you back up is the itunes media file and mobile applications?
