Permabanned
- 9 Aug 2008
I'm perfectly happy![]()
No you are not, there is something going on.
// Hugs
Just wanted to know why the sudden change in your posting style, is there something you need to tell us?
I might just send it back to you with a turd in if that's ok?
That's fine. I will make a post in GD telling everyone what you have done if you do it and I will also take pictures for everyone to see.![]()
What an outrageous concept![]()
I know
Anyway, it looks like an (apparently) **** thread, is now a derailed **** thread. I was going to keep coming back in here and ressing it whenever I climbed the man points ladder as well![]()
You've probably gone back a couple by being so offended by a question :/
Well my wallpaper is off and now painting. God painting can be frustrating and very time consuming.
paintings easy if your using paint pads and takes almost no time unless your trying to spread the paint out loads but then you need more coats anyway
what's the manliest job?
Building a house, level 500.
Oooooooh my, that is pretty manly. What level would laboring come under?
