I've had a Frio keeping my 2500K at 4.2ghz and 65C or less under load for a couple years now, but I'm migrating the 2500K to my gf's build next week and I must have binned the stock cooler so I have to pick another one up. Here's the dilemma:
Do I:
1. Buy something cheap to keep her 2500k acceptable at 4ghz and continue using the frio for my 3570k, which will have the nuts clocked off of it, and hope it's up to the task.
2. Give her the frio and upgrade at a pretty hefty cost to get the most out of my chip?
I'm leaning towards 1, so what budget cooler would you recommend for a 2500k at 4ghz for around 25-30 quid?
Do I:
and having given up the best you 'settle' for a new , but not as good( how 'good' is interpreted I leave to your imagination), cooler for the 3570 .
