How do you solve the Chair vs Carpet problem?
Permabanned
9 Aug 2009
UK
I've got a pro computer chair with wheels and it destroyed the carpet here. Ended up with a lame plastic layer under it.
Moving soon and want to protect my new carpet, want rid of the plastic thing - so.. what do you do?
Huh? You want to protect the carpet by not using anything to protect the carpet?
You either get a chair without wheels, or remove / cover the carpet
Years ago I remember when we had new carpets fitted in our old house, we had an off-cut of carpet made into a rug for the study. So it was the same colour but the carpet below was protected :) All that was done was it had the same kind of edging that the samples of carpet usually have in shops.
