I've finally booked my 3 week camping safari and so am now looking in ernest for a decent lens to take with me...
I currently have a D7000 (for about a year) and a 70-300 VR. The 70-300 is ok... as a stop gap but not what I want to be taking with me.
I've been searching around for options over the last few months and drawing blanks a lot of the time. I'm not too keen on a super zoom (80-400, 50-500) because they are fairly slow at the long end and also soft where you need them most (the long end). That leads me to one of two options, either a nice prime or a shorter zoom.
With the shorter zooms I'd be looking at using a TC as well and from what I can see I have two options, the Nikon 70-200 VR or the sigma 120-300 OS. Both f/2.8 so I can stick on a TC and still have a fast zoom (with good AF) but the 70-200 I think will be just too short? The Sigma is subsequently my preferred option, I can get 420mm f/4 or a 600mm f/5.6 out of it, although with the 2x TC it's supposed to be a bit soft? The other problem is it's huge... 3kg...
For the prime side of things I only really have one option with Nikon... the 300 f/4, however it's expensive for what it is, and most of all it doesn't have VR which for me is a killer (having owned a 300 f/4 without IS/VR before). I could use a tripod all the time but that removes all the spontaneity, I'm not sure companions and guides would be very happy either... An f/2.8 OS/VR lens would be great, but out of my price range.
Now to the "Is this a stupid idea" part... I still have my old 400D, works fine and it's a great little camera... The Canon 300 f/4 IS is also several hundred cheaper than the Nikon non VR, and the Canon also has IS... For £1k I could get a 300 f/4 stabilised lens and a good 1.4TC... and take two bodies with me, the 400D and the D7000 (for the landscapes)... Am I being stupid? Are there any other options I haven't considered? Anyone want to sell me a Nikon fit f/2.8 300mm prime for less than £1300...?
And for those that have done safaris what lenses did you use (going to several locations, including the Ocavango and Namibia, so I'm guessing long is the call of the day)?
Thanks
Thanks
