is this one of the many dream threads again?
will this actually be built or is it a massive waste of time?
best to give a budget and what you want it for, or you may get lotto answers.
and quickest doesn't mean best either, as with no o/s it's just a pile of parts.
please remember only windows 8 pro and above supports dual cpu's, but very few programs do, and no repeat none games do!
i stand corrected, my info was off m/s
anyway, it wont do more than 2 cpu's and 4 core on each then, windows 8 will
quote "16 core / 32 threads and 48GB of RAM"
wouldn't work on windows 7 pro ^^ etc
says unlimited cores, which isn't true...
Obviously Win7 seems to be unable to handle more than 8 processors in the system (ie 2 x 4core, or 1 x 4core + 4 hyperthreaded)
unless it's been patched by now?
snip
you did say money no object
YOUR BASKET
2 x Intel Xeon E5-2687W 3.10GHz (Socket 2011) - Retail £1499.99 (£2,999.98)
1 x OCZ RevoDrive3 X2 960GB PCI-E SSD - (RVD3X2-FHPX4-960G) £959.99
2 x OcUK HD 7990 6144MB GDDR5 PCI-Express Graphics Card £719.99 (£1,439.98)
1 x EVGA SR-X Dual Socket (Socket 2011) Motherboard £559.99
1 x Seasonic X-Series 1250w '80 Plus Gold' Modular Power Supply £219.98
1 x XSPC Twin D5 Dual Bay Reservoir/Pump Combo £199.99
1 x Hitachi Deskstar 7K4000 4TB SATA 6Gb/s 64MB Cache 7200RPM - Retail (0S03356) £179.99
1 x NZXT Switch 810 Big Tower Case - White £139.99
3 x Samsung Green 16GB (4x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual/Quad Channel Kit (MV-3V4G3D/US) £93.98 (£281.94)
1 x Asus Xonar D2X 7.1 PCI-E Sound Card £89.99
1 x LG BH10LS38 10x BluRay-RW / 16 x DVD±RW Lightscribe Drive - Black (Retail) £79.98
2 x Koolance CPU 370 CPU Waterblock £76.99 (£153.98)
2 x EK CoolStream Radiator XT 360 (120.3) £48.98 (£97.96)
1 x XSPC RS240 120mm Radiator - Black £38.99
8 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack £25.99 (£207.92)
2 x XSPC HighFlex Hose 1/2" ID, 3/4" OD, 19/12.7mm, 2m, Blue/UV Blue £6.98 (£13.96)
12 x OcUK 1/2" G1/4 - High Flow Style - Black Nickel - Compression Fitting £3.49 (£41.88)
Total : £7,726.78 (includes shipping : £16.85).
passey89, you appear to have missed a couple of these
http://www.overclockers.co.uk/showproduct.php?prodid=HD-082-OC&groupid=1657&catid=2101&subcat=2199
Passey, that's an interesting take on liquid cooling... no pump?
What are you two on about.. Look closer....
Ok, money no object what would everyone recommend for the ultimate gaming rig at the moment? I want best case, best cooling solution, best everything.
Thanks in advance,
