*** Official OcUK Minecraft Server - Discussion and Rules ***
Is minecraft having a few problems at the minute? I cant connect to any of the linktart servers, and even my own small FTB server, which is showing as up and running on the kerplunc site, seems to be down as well..
I just managed to get on the reddit server fine.
But the LT servers are down because FT is moving it to a new box. No idea when they will be back up. The test mod server is up though.
And just because even I found it hard to find details of all these servers.... and all the posts asking for IP's and version numbers... for reference...
Vanilla 1.4.5
linktart.co.uk:55565
Mod+++++++ 1.2.5 (need custom client here)
linktart.co.uk
Vanilla test server 1.4.6
rootserv.co.uk
Mod++++++++ test server 1.4.6 (need custom client here)
rootserv.co.uk:45565
Thanks for that toString :D
Just to let everyone know the 1.4.6 test server is up, not sure about the 1.4.5 at the moment due to the dedi soon to be changing.
If the test server is stable then it will become the main server very very soon :D Everything has been transferred over and from everything I can see it is running fine! But please let us know if you spot anything.
so, I dont know much about these modified servers, I only used the tekkit one once and never liked it, what is this Mod+ one going to be like?
Unfortunately if you didn't like tekkit your not going to like the new Mod+ server but if you don't want to use any of the new machines you don't have too and can play vanilla albeit there are a lot of ores that you won't need, there are a few little additions to anyone that wants to play sort of vanilla with a few extras use nei (search bar at the bottom) and look at the furnaces :). Also xycraft (those colored light emitting ores) has been added and make for some great looking building blocks
are there any computercraft gurus about? i'm having a problem with my quarry control program that I honestly don't know how to fix
*edit*
never mind, i fixed it and the quarry is working :D.
i was being a retard and used the wrong function in about a million places. i only wrote three functions in this program yet I still managed to pick the wrong one.
*/edit*
on the 1.4.x server thaumcraft could be a welcome addition for someone who doesnt like the machines of tekkit/FTB
Vanilla 1.4.5
linktart.co.uk
rootserv.co.uk
Since no one has said anything officially, I'm going to make the following assumptions, so anyone feel free to jump in and correct me :P
The 1.4.5 vanilla server that was on linktart.co.uk:55565 is now gone. It is now moved to linktart.co.uk and upgraded to 1.4.6.
The mod+ server that was on linktart.co.uk is now down and not moved to any other address until further notice.
The vanilla test server that used to be rootserv.co.uk is no more, and we can ignore any server with 'rootserv.co.uk' in the address (for sake of clarity, even though it resolves to the same IP).
^As such, the Mod+ test server that used to be on rootserv.co.uk:45565 can now be found at linktart.co.uk:45565 - and is up.
I'm not really up on what is happening myself so I can't comment. However, yeah, the old dedi is gone for the most part and anything that is being moved has been moved. linktart.co.uk should now point to the new dedi (as does rootserv.co.uk)
regards the 1.2.5 mod+ server
it will not be comming back as the last issue on the map killed the map
I am working on that issue and IF i can fix it i will release the map
to the players to have a copy of it.
The NEW 1.4.6 MOD+ server is what we will be going forward with and
we wont be doing build moves. We have many reasons for this and will explain them later when we have finished the information document.
There have been many changes and a lot of new mods.
much testing has been done. but MCPC is no longer an option so we have had to work on a whole new system of managing the server.
Some admin stuff is still in alpha and not yet completed but we felt we wanted to let players play on the mod+ server with all the new stuff from 1.4.6
More information will be coming soon.
I unwelcome the mod+ server but I hope the vanilla one is still going, so WE WILL NOT BE MOVED! xD
also Lockette atm isn't working, I'm sure its not updated yet
I'l just have to grab a video of my build then before the wipe : P (If the map isn't dead ^^), so busy these days to get on though... silly other games lol
i believe that everything you build on the test server will be kept. dont quote me on that though
Yep we haven't had any major issues on the version we have tested as best we can over the last couple of months (yes months). So we will be trying our best to keep the world on the 1.4.6 MOD + server (our private test server is already on 1.4.7 :S) if any mod update adds new ores or world gen then we will accommodate this in a mystcraft world (this also works 100 times better then the 1.2.5 version).
The reason for the extra whitelisting is simply because as yrth said we have no rollback command also there is no TP command currently (to get around this use mystcraft linking books if anyone wants to make one give me a shout and I will enable same world linking for you) again this is because the plugins for this are in development but we are updating (yes this is a pita) but each update should be more stable and add more features, we will only inconvience you once we are happy the update doesn't break anything (possibly once every two weeks currently and then less once everything calms down)
We will try and get a modlist together before the weekend and post it on the linktart forum.
Here is a rough list of what has been added from the major mods -
everything you had on the 1.2.5 minus the ic2 - buildcraft crossover mod (we felt that with what we have added this was redundant)
Portal Gun (moon shots are off before you get any ideas)
mavity gun
Thaumcraft
Factorisation
Thermal Expansion
EE3
Gregtech (yes your matter fabricators and quarries are much harder to get)
Xycraft
Camera Craft
Extra Biomes
Secret rooms
Soul Shards
and more.....
Also there are a lot of client plugins but i won't spoil what that brings :)
Again we have tested as best we can by simply playing the game but if anybody comes across a problem or error please let me know and i will try and compile a short list of can's and cant's.
it will not be coming back as the last issue on the map killed the map
As some one will ask anyway, if it can be fixed, would it be possible to move an area over or the contents of chests (diamonds, UU blobs). I'd just got myself sorted and I don't really want to have to start all over again (again) :(
May I be whitelisted for the 1.4.6 MOD+ server please (horse_uk I think ?)
Huge Problem:
I downloaded the client from the Dropbox thing, but the instructions on linktart make no sense to me at all, I can see some words relate to some things but they don't match what you appear to be saying :confused:
May we have an idiots guide please, written for idiots, in small sentences, step by step. Ta thanking you :)
I can confirm this.
Managed to sort out toString's chest issues
