- 15 May 2012
- Louth, lincs
just been reading through a very long thread on a build log, and its amazing, the detail is awe inspiring, just have a look.
http://www.overclock.net/t/1266202/build-log-the-big-budget-boomer-box-aka-the-bbbb/2740
heres the mobo etc, a work of art!!
and heres the spec list
Case
CaseLabs TH10 with Pedestal and extended tops
Main Guts
CPU: Intel Core i7-3960X
Motherboard: Asrock Extreme 11
GPU: 2x EVGA GTX 690’s
Memory: 64 gb, Corsair Dominator GT 1866
PSU: 2x Corsair AX850. Probably could get by on one big PSU, but this setup will allow me some additional overhead, and as an added benefit, it should keep the PSU fans spinning at a minimum
Storage
Raid Controller: ARECA ARC 1882IX16 PCI-e 3.0.
OS Drive: 2x 256 gb SSD Vertex 4 in Raid 0
Raid 5 Array (for storage): 10x 512 gb SSD Vertex 4
Raid 0 Array (scratch drives, render drive): 4x 256 gb SSD Vertex 4 Series
Cooling
Radiators: 4x Hardware Labs Black Ice SR-1 480 Radiators
Radiators: 1x Hardware Labs Black Ice SR-1 280 Radiators
More Radiators: 2x AquaComputer AMS 360 Copper Fins
Pumps: 4x D5 variant (Swiftech MCP655’s)
Pump Top: Bitspower Dual D5 Pumptop
Pump Top: 2x Bitspower Pumptop V2
Pump Decoration: 4x Bitspower D5 Modkit
Reservoir: Some Custom Work from FrozenQ
Radiator Fans: 47x Noiseblocker M12-S2's
Case Fans: 4x Noiseblocker 40mm Black Silent
Case Fans: 4x Noiseblocker 140mm Black Silent
CPU Waterblock: Mips Iceforce Custom Copper Plated
GPU Waterblocks: 2x AquaCompuer Aquagrafx 690's
Motherboard Waterblocks: Both the Mips AE11 block and the Nateman_doo custom AE11 block. Will test both and winner stays!
RAM Waterblocks: 2x Mips 4 Dimm Block
TIM: Indigo Extreme. Kind of scared to try the “reflow”, but it will be an adventure
Tubing: I'll be using a combination of white, clear and custom dyed crimson.
Fittings: Bitspower White!
Monitoring and Control
AquaComputer Aquaero 5 XT
AquaComputer Aquaero 5 LT
12x AquaComputer Power Adjust USB Ultra
3x AquaComputer Flow Sensor Block
Lamptron FC8 for Case Lighting
6x Water Temperature Sensors: AquaComputer
5x Air Temperature Sensors: AquaComputer
Case
Main Guts
Storage
Cooling
