Just arrived, busy setting it up, so far so good, slight scuff on the top left corner other than that mint
smartfonestore?
What grade?
smartfonestore?
What grade?
mine has left the depot and should be delivered today.
this thread is huge is there anything specific I should be getting or doing when I first get the phone?
rotters
Yes, first thing every Note 2 owner should do is double tap the home button to go in to S-Voice, bring up the settings for S-Voice and turn off the double tap to launch.
By default, when you press the home button it waits nearly a second before taking you to the home screen just in case you might press it again.
can these take 32gb or 64gb micro SD ?
Yes to both
I recently got a 32gb micro sd card but for me personally its kind of useless since my apps take up the most room and they all install to the internal card and even using a third party program i couldn't manage to transfer them across to the Micro SD.
i believe there is a way to do this (rooting your phone) , someone else will hopefully confirm how
for me, its for music, photos and video
I believe gl to sd is the app that you're looking for. The other solution is doing a directory bind. If there are any other ways, i'm sure someone else will chime in.
Directory bind is by far the best solution. Re bind the Android and gameloft folders.
