Anyone running a Z77X-D3H and an Asus Xonar PCI-E sound card?
Caporegime
29 Jul 2011
In acme's chair.
Recently I built a PC for someone and the system would not boot with the sound card connected, but it would without it connected.
The sound card is an Asus Xonar DGX.
The sound card worked fine in another system. Has anyone experienced anything like this, and did you/how did you resolve it?
I will try it after a BIOS update soon, but I don't believe that Gigabyte boards can flash a new BIOS image onto the chip from within the BIOS using a quickflash method like on my Asrock, so i'm a little hesitant because of the risks.
Any ideas?
I thought the z77x-dh3 was a Gigabyte board?
I have used the quickflash in bios before on my z77x-dh3. I only use the PCI Asus DG tho.
Yeah its a Gigabyte board, sorry.
And ah OK, so the quickflash BIOS from USB device like a flash drive feature is present? :p
Pretty sure I suggested you update the BIOS. I usually say how to aswell. You press the end key on the keyboard on startup to load the BIOS update utility (Qflash). Make sure you extract the file you download to the USB drive, don't just copy it straight onto the drive ;)
Hello hono :D
Cheers. Haven't had a chance to go round there and sort it yet, so I guess I was seeing if anyone else has had the problem in the mean time :p
Hello hono :D
Hey bud,
Tut tut someone doesn't read the manuals and specs of the kit they buy. The gigabyte mobos have a dual BIOS so it's infact safer to update than your Asrock ;)
Also, I think one of the 1-4x PCI-e is shared with one of the GFX 16x PCI-e slots. U might wanna check that out. It could be the bottom GFX PCI-e and the bottom 1-4x PCI-e.
Hey bud,
If I read the manuals, the motherboard in my sig wouldn't have blown up ;)
I'M A MAN! I DON'T READ MANUALS!
and it will be my downfall...
I'm having the same problem, with the exact same motherboard and soundcard - I just tried updating the Bios to F18, and it's still not working! Did you do anything else, like change any particular bios setting? Did you upgrade to F18, or was it the new Beta one? I'm a click away from sending this frustrating card back!
Many thanks!
Many thanks!
I just updated to F16. I didn't touch the beta one. (F17)
It could be something to do with a setting in the BIOS in your case, but I really have no idea, sorry :(
There is no F18 BIOS for this board yet, so i'm guessing that you have the Z77-D3H and not the Z77X-D3H?
got the same problem, my pc with gigabyte z77 d3h and asus xonar essence stx wouldnt boot with sound card pluged in, but would without!
q-flash bios update solved the problem, cheers guys!
I spent 2 days trying to find a solution and yes! finally it is! so simple.. if you know it ;)
