- 11 Aug 2006
- Pembs, Wales
What mod are you using for ore generation as a lot of mods are switching to a new system to prevent strip mining at one level to get yer resources. Different ores will be found at different levels. Below if rough guide of the way ore is distributed.
Lvl40: Copper, Iron, Lead, Tin, Apatite, Coal
Lvl26: Iron, Lead, Silver, Tin, Gold, Ruby, Sapphire, Emerald, Apatite, Coal
Lvl11: Iron, Diamond, Gold, Ruby, Sapphire, Emerald, Coal
Mod creators are working together a billion times better than they used to thanks to the FTB launcher (not sure if the server uses a FTB setup (dont think it does) but even so because of FTB it will have an effect on the way mods work together increasing compatibility and stability.
I was using King_lemmings setup.
I have resorted back to ic2's tin and copper and had a good mine in the digger world trust me there is plenty for all.
Nutty - do you use mumble at all as i would like to have a quick chat with you
now I'm struggling again with that Dropbox thing as the site seems really iffy and refuses to download. It did this last time, maybe it doesn't like large files ?
