TBH I think you're bang on the nail right with 000f and that maybe where the 800 came from.
Do you know if 000f is still available somewhere and would a backward flash be OK?
Thanks wazza300
I just find it a bit odd that I've had + 800 in the near past.![]()
Yes you are correct. You should be getting around 800 with a correct installation on SATA3.
you went from win7 to xp![]()
ahh your forgiven then
you did right click the .exe in the dvd/properties/compatibility/run in xp mode?
yeah a secure erase will restore the ssd performance
did you get your program to work in xp mode?
