- 22 Jul 2010
- Kent
If you have the antec 300 with the cut out in the mobo tray then it should be good for 160mm tall heatsinks.....like the TS120 I spec'd
Does leaving a PSU on standby (it has its own power switch) prolong its life? As i never turn the power off at the wall. Just a random thought as everything would still be taking some power i guess?
Well 8GB in the system 12GB total, can't say i notice much difference
How much is a "fair dolop"?
You literally only need a dab of paste, roughly the size of a grain of rice if that.
Possibly too much, or you may have just not seated it properly - try removing it, cleaning off the paste and trying again.
Alternatively, there may be a reason it was £1...
I have given up with the £1 jobbie and gone back to stock again. Sitting here with chrome open+core temp.
0 77
1 77
2 77
3 77
as soon as i go in Anno it goes above 100+ and comp resets
Are you cleaning off the old paste? Those temps are too high at stock!
