- 21 Aug 2012
Yeah, Black Cleaver, Bloodthirsters, LW, IE, GA.
She is very strong, still lacks the sustain but the higher level you go the better she is. Lower level the lack of sustain for her ad makes her ad an easier target![]()
yeh shes a bit pants if you have an AD thats a bit suicidal and never buys pots, but generally I think shes pretty neat.
Are they really nerfing Eve? my god her ulti isnt exactly all that powerful, they better be nerfing amumu in the process and sorting out blitz so that he isnt always insta banned 99% of the time!
Does anyone here use smartcast? was thinking about trying it out, any advice if im going to use it?
Cheers.
Yea the sooner you make the transition the better imo, otherwise it feels too strange as I've heard from other players. I use it for all abilities including the 1, 2 and 3 keys for item actives.I leave my ult, R, on normal cast.
You could also try the hybrid kind of thing where it casts on key up instead of key down allowing you to display the range indicator but I don't like it.
what is smart casting?
