I'd rather have any of the direct competitors.
The Vectra really is a nasty place to be.
Why ?
For a £2k budget?
I'd recommend saving up more money.
What's your objection to Mondeos?
Saving up for what
There is nothing wrong with the Vectra and as per another thread you can pick up Vectra C 1.8 SRi's with sat nav, air con, cruise etc etc for under £2k. They are reliable and simple to maintain and fix.
Only when taken in isolation, why spend the same money and end up with an inferior product, you wouldn't do it with PC components so why put up with it in cars?
Lol. Sorry for the spelling what do you recomend i save up 4
I have never found a vectra inferior to a Mondeo. Both are about the same and for £2k you would be best just buying the better of whichever turned up.
Personally I think the vectra C is a better car than the Mondeo of the same age but that's my opinion.
Oh the ironing.
As has been said - the Vectra and Mondeo are very similar cars. Both boring, cheap, imageless large hatches. If a Mondeo isnt for you then the Vectra probably isn't. They dont have a better image or do anything better than the mondeo at all.
The Mondeo does a lot better than the Vectra - reliability and handling namely. If you dont like cars like that then fair enough, but the Vectra offers nothing over the Mondeo
Well i can only conclude you don't know much about cars.
theyre gud cars m8. get one in sri trim if you can though they come with extra toys n stuff i think.
That seems pretty fair to me,I seen a few for less than 2k miles are less than 60k and like 8years old.
