- 5 Jun 2003
- Falling...
Make your own protein flapjacks!!!
Short of randomly shaking a tub theres no easy way I don't think. That or buy a few small containers and make some batches every weekend for the week ahead.
^loads of carbs and fats, you're better off with mars bars than those and at least they taste good.
Tee CNP Flapjacks are pretty lame as well, nowhere near as good as myprotein's cookies (both taste and nutritional content wise). I've been struggling to get through a box for ages.
Cheers mate, may get a couple.
Big being the 10000ml or the one Syla5 mentioned?
BSD's Super Omega 3s are among the best out there with really good ratios.
BSD112 if you're interested.
AAKG/L-arginine.
Yeah there is a 10l I believe, need height dimensions of the thing reallymake sure it fits on my shelf!
Either way the one below should be good enough
Thanks LiE, just ordered some Primaforce AAKG - hope it's good![]()
Not to worry, but you know for next time. Does your sponsor not do items like this?
But kai, for you, Citrulline Malate would be brilliant. Makes you vascular and pumped as fuuuuuuuuuark. Seriously, I rate it more than AAKG. Imo AAKG is a bit turd unless you take a lot, and then it becomes far too expensive, also a lot of pre-workouts/pump supplements are moving away from making AAKG a core ingredient in place of other things. But Citrulline Malate, take 3-5g of that pre-workout, you'll definitely notice it!
Primaforce do some too
But it's far cheaper on MyProtein or OneOn
