PLease don't spec the Merc Alpha or Beta.
Don't order me around. Moreover using your tone please don't spec a secondhand HDD which only ever had one in stock either.
			I'd rather go with the build with the 6870 tbh as a 7850 is overkill for his screen, and the i5 simply treads all over the 6300. The graphics card is also simpler to upgrade.
The FX6300 walks over a Core i3 in games like BF3,and so does the Core i5,so why don't you say the Core i5 walks over a Core i3?? Funny that,especially when I also suggested alternatives.
Considering that I had a Core i3(now on Xeon E3),people seem to put the Core i3 on some pedestal of brilliance while never owning them.
The HD5850 1GB/HD6870 1GB are already hitting issues now. I actually use one of them now. Even with the same amount of VRAM,the HD7850 1GB is at least 30% faster overall in things like BF3.
The tessellation ability of the HD5000/HD6000 is starting to be a limitation now.
			http://www.anandtech.com/bench/Product/540?vs=549
compares 6870 to the 7850 considering that 6870 cost 80 quid less id say its more than a bargain. (or 50 quid less that the 1gb version 7850)
and paired up with I5 thats a whole lot of build for the money
Anandtech Bench for GPU uses old drivers,and is never a good thing to use.
The single fan HD6870 runs hot,unlike the dual fan versions which were the standard XFX fare.
Moreover,perhaps some of you conveniently ignore the RMA procedures of XFX which are horrible.
They do not do full replacements in many cases and do partial refunds on time used.
Moreover,considering that I actually showed away to get both a Core i5 and a HD7850 into the build,yeah both can be done.
OcUK had loads of that Z68 motherboard and the feedback is at least from people like Martini1991 is they are in good condition,and it was decent budget Z68 board at the time. I suspect they were the new RMA replacement stock which OcUK probably got a deal on.
