Ok here we go. I haven't met anyone that doesn't like pulled pork. This dish requires preparing a day or two in advance.
This is by far one of my favourite dishes, but the first time I've ever attempted it. And this is the recipe I've come up with after some research.
This will feed roughly 6 people, or make left overs for the week
.Ingredients for the Rub
- 1 2.5KG pork shoulder - skin on
- 3 tbsp Paprika
- 1 tbsp garlic powder
- 1 tbsp brown sugar
- 1 tbsp dry mustard
- 2 tbsp coarse sea salt
- 1 tbsp cracked black pepper
- 1 tbsp chilli powder (how hot is up to personal preference, I'm using hot)
Sift all the ingredients together, and then mix well with a fork.
The next process is to simply rub the shoulder joint all over, making sure to work the mix into the meat as much as possible.
Then once complete, wrap tightly in cling film and refrigerate for 24 hours.
Cooking
Preheat the oven to 150oC (140oC fan). The joint will need to slow roast for roughly 6 hours (I put mine in the oven at 8am this morning, and cooked it until 2pm). When a sharp knife pierces the skin with little resistance, and comes out clean you know it is finished. Take out of the oven and rest. Meanwhile, make the barbecue sauce and spicy coleslaw (below)!
After letting the meat rest for ~15 minutes, it should be ready to pull off the bone. Using two forks, it should simply fall away.
Then, put some of the barbecue sauce into a bowl with the pork, and mix in.
Serve with the spicy coleslaw, and some wedges or fries.
