i dont know why motoactv is not liked really.. it does the job and it has a lot of great features!
The fact that it isnt as popular as the garmin probably has nothing to do with the features and more to do with the fact that the garmin was around before it and, more importantly, a lot of pro teams have garmins stuck to their bars.
screen is lit up all the time while cycling(Great at night)
the only con tbh is the battery life in my case which will last 5-8hr ride at MAX
Can you turn the light off? Maybe thats why the battery isnt very good.
Garmin has pretty good battery life actually, i'v recorded 14 hours with mine before and i think it still had around 20-30% left in it.
Indeed, I've used my 800 twice a day, at minimum 5 days a week for the last 7 months on my bike. I also use it as sat nav on my motorbike.. both through horrendous weather conditions at times and its never failed me, not even once.
Does it have maps/navigation?
Christ you can root the thing and run android apps!? http://motoactv.wikispaces.com/That is the only feature missingyou can see your route on the map tho..
Schwalbe Marathon Winter tyres = thumbs up from me. I did have to walk up one hill though, as I couldn't get enough traction on the back wheel. Better than getting the tram!
