We're getting power cuts around my area due to the snow (no idea how)?
I have a OCZ 650W 'Bronze' Plus or something, is that safe? :/
Cheers for the help dewdz.
It should be enough. It's not a guarantee - if you want a guarantee, get an Uninterruptable Power Supply (UPS) - but it's very rare for a power cut to do any severe damage. My PC sat in a corner where it was quite vulnerable to the plug being kicked out, must have happened 20 or more times with no issue.
It should stop any major damage being done, though. Worst case, you might end up with a corrupted file on your HDD as it gets a power cut part way through writing. The myths about blowing up your PC are from a few years ago when components were far more fragile and PSUs/power circuitry were much less advanced.
Are you connected to a surge protector at all?
That's a load off my mind, then, couldn't care much about file corruption as most things on my HDD are games that can be revalidated anyway.
Is that like a plug extension? Could get one tbf, I assume they are fairly cheap?
Can't complain for 8 quid tbh, will invest, cheers!
Reduce the noise of what?![]()
if your using a powerline kit as well the belkins also reduce noise so they improve powerline speeds slightly
I had a powercut once, it somehow fried the ethernet port on my asus p5q deluxe motherboard![]()
Everything else was fine except the ethernet port.
