Road Cycling Essentials
Status
Not open for further replies.
See above re the wheels. I was talking to Wally the other day, when we were fixing my brakes, about the rides they're planning, but I can't remember which ones he said he's planning for. Not sure which if any I'll be doing, but I'll see how I get on.
Wally said they're doing the Jodrell Bank one and then the Cat. That's all he mentioned. That plus doing the rake a few times to practice inbetween. I seem to be the only one I know doing the Rochdale one despite it being sold out. Maybe we're just all mental for doing one so early in the year. I'm planning on giving the rake another go asap now that I know what its like. It's bloody tough going as you know but can you imagine how fit you'd be after doing that a few times a month? You should try and come along you know, if only for the Cat.
~1 month of london(dont forget the snow and salt and grit this last week)
im not sure if its worth cleaning really, i guess ill keep it lubed(heh) and it'll slide.. down the road fine for now.
i have! crud mk2.. back is alright! i've lost the front bottom peace and the nose bit i couldn't fit it.. there's like 1mm clearance! and these are 23mm tyres.. :(
Thats annoying, i was thinking of getting a triban 3 and sticking some full time guards on it - why bother with the eyes!!?
back is OK for mudguards(well for cruds which are meant to fit a lot of bikes) but front.. the "bit" you see below the brake is the "connector" thing for the nose part but if i put it on(which should stop some of the mud) it'll rub against the tire.. once braking the nose piece moves around too.. this is what causes the rubbing :)
so yeah triban 3 and mudguards is not the best idea! but it does the job OK in my case :) back is clean front is fine too! only shoes get some crap on them and front is literally covered in it as you can see.
Googling turns up loads of threads with people complaining about not being able to get decent mudguards on the Triban 3.
Though there is someone here saying they got "SKS Raceblade Longs" to fit OK.
I just don't ride in the rain problem solved :p
Picked up two punctures in the last week after riding 2500km without a single one. Found nothing in the tyres either, had a front and a rear so not like I missed something stuck which popped the second tube!
Cheap Chinese ones in there, swapped out for a Schwalbe and ill fix them when I get the time.
Another good stage of the TDU, a lot of riders being caught out by the roads though, there are generally no kerbs, the seal on the road just finishes and it turns into the road base for about half a meter then drops into a drainage ditch.
Seen quite a few riders being pushed out onto the dirt and a few taking that line to work round to the front of the peloton. Risky business at speed, risk a crash or puncture!
just another reason why buying cheap isnt always the bargain you think it is...
Well quite, i was just after a winter hack - i have cruds on my ribble, back fits fine and front is just in need of some tweaking!
Seems odd to have mudguard eyes but not long drop brakes but i think boardman do the same!
I kind of like having a heavy bike as my commuter, it makes jumping on my road bike all the more of a treat :)
That and also riding the commuter helps me increase power due to the weight of the bike, the crappy power transfer and also the fact that I'm lugging round a 7kg backpack whilst doing it too.
[Damien];23625317 said:
Edit: Combined bike/rider weight at the mo = 101.59kg *sigh*
My bike doesn't weigh 4kg :p
I have not the foggiest why people would commute without 'full' mudguards. I see plenty people riding winter without them, I don't get it. Living in this country im riding my winter bike 80% of the time.
[Damien];23628682 said:
Haha, what bike you got?
It's a Ridgeback Flight 02 Disc, 2010, bare it is 11.6kg, but it's got 2 front lights (one which uses an external battery pack so kinda weighty) a rear light, full mudguards and a bottle rack.
Probably 13.5kg worth of bike.
7kg backpack.
97kg of me.
The Boardman Team Carbon is 8.3kg.
I don't have a summer or winter bike, just one road bike and a TT bike. So I try and only take my road bike out in decent weather, but that's not always an option. I do commute every now and then, so for me I don't see the point in mudguards. I'm happy to clean my and service my bike regularly myself. And I'm also happy to get a wet bum on occasion :p
So that's my reasoning for not bothering as it'll spoil the look of my bike too :D
And I rarely group ride
7kg backpack.
97kg of me.
I reckon with the chunky front lights I've just stuck on and the frame pump mine hits about 12kg. No idea what my backpack weighs though. How tall are you? 97kg's a bit on the heavy side. I thought I was bad at 90ish kg (@ 5'9).
I'll probably buy a nice carbon bike if I can drop a good 15-20kg. No point until then. It'll make climbing a lot more fun I'm sure.
Status
