Hey guys, this is going to be my first water cooling build, just wanted your thoughts and opinions of it. Its all going into a Corsair 900D
XSPC RayStorm CPU WaterBlock (Intel) - for my i7 930
XSPC D5 Dual Bay Reservoir/Pump Combo
x 2 XSPC RX360 120mm Radiator - Top of case and bottom
x2 XSPC Razor GTX680 GPU Waterblock (Raystorm Style) - for my GTX 670 FTW's
XSPC Razor SLI Flow Bridge <-- Hopefully its long enough (... LOL)
x6 Scythe Gentle Typhoon 120mm 1150 RPM - 3 Pin
XSPC HighFlex Hose 7/16" ID, 5/8" OD Blue/UV Blue 2M <-- Already have 4 UV Cathodes somewhere in the house, hopefully i can find them and hopefully they still working
x 10 XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) <--- Will buy other fittings if needed (90 or 45 degree)
Now thats all the parts, just the fluid left i think
, What should i put in here? I was thinking of just throwing in Mayhems Ultra Pure H20 Watercooling Fluid, with a Kill Coil, but is that all i need in terms of Fluid? No other anti corrosive stuff?? Or are there better options for fluid??
Thanks in advance for your help
