*** Desk and Room Gallery***
Just finished reorganising my desk area, resorted all the wires and added some more cable management tubes under the desk to fit more wires in, in the end a good old spring clean.
Only problem is that because I added the 4th monitor on the far right, it blocks where I normally shine the projector.
I tried using a 32" tv as a monitor but I found it rubbish, the resolution was capped at 1360x768 when using as a monitor though I guess yours goes higher? I found it pretty nasty tbh and I only did it as a test. Could never live with it.
I actually like using my 21.5" 1920x1080 monitor, games look pin sharp and the size I find large enough and I like how manageable it is.
Yeah, it's a 42" 1080p HDTV. Picture is sharp and nice, the montiors are HP2405wgs 24" at 1920x1200.
I always been against 1080p for PC's and gaming, but I totally fallen in love with big screen gaming so much that I really would like to sell my 3 monitors and get two more 42"s for Eyefinity instead.
The old plan was to use the 3 24"'s and stick the HDTV on the wall, but just can't bring myself to do it.
Agree with that!! i have a 32" lcd running 1920x1080 for gaming and its lush, begging the mrs to let me upgrade to a bigger tv!!!!
My new set up, idea was inspired by the ocuk mega xl mat.
built desk into cove so all wires are inside the desk almost like a floating shelve.
then rebuilt pc into TJ08e case coming from zalman HD503 htpc case.
only thing i could hide was the wire coming out the left which is optical cable going to amp.
After buying a new case, the Silverstone raven rv-03,cpu cooler the Thermaltake silver arrow extreme,and a couple of 120mm Noctua's,along with other bits and bobs,I striped down my desk,threw the monitors up on the wall and gave it a good clear,of all the clutter.And in my opinion it looks 100% better.Here are a couple of pictures.I will post some pics of the rig,and update my specs over on the other section.The pics aren't great quality,having to use my phone as my camera's batteries have run out,and I've lost my rechargeable's.
Not great quality pic due to low light but note the PC in the right position on the floor ;)
Just need to get 23" to replace the 20" screen sometime.
Where did you get the desk?.
The desk is from Ikea but have no idea which one it is sorry.
dacads
There B&W 600 S3 and Im hoping they don't fall off. The picture is a women holding a pint glass with (A Great Women) in text below it.
Chris
