About to purchase
3 May 2012
Far away
Motherboard: Asus P8B75-V Intel B75 (Socket 1155) DDR3 ATX Motherboard
CPU Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W)
RAM: Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
About to purchase these items, But before i do buy these i just want to see what you guys think and if you think i could get anything better for my money?
Thanks
CPU is fine, can't comment much on the motherboard as I am still learning :p
The RAM, I have seen plenty of people reccommend the samsung 2x4gb kit that is on offer but not sure how those 2 compare.
Is this better than the current board that i have put down?
I'd recommend you go for this one if you can strech....
http://www.overclockers.co.uk/showproduct.php?prodid=MB-391-GI&groupid=701&catid=5&subcat=2261
It's been given best budget board award and you get UK RMA.
Hmm can't really strech that much and i don't like the look the blue puts me off it :(
Good choice although if your decision was based on the DVI port then you could have bought an adapter to use on the LX2 for VGA ;)
