** Hot New Additions to the OCUK Range - TP-Link **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Guys
About to go live, we have an excellent new range of higher performance TP-Link products.
Price points for these products are a little higher than our current TP-Link range but after some testing of a large range of samples, TP-Link have really set these products aside as being higher end offerings.
Performance, interfaces and aesthetics have all been subjected to an overhaul here.
TP-Link Dual Band N600 Concurrent Wireless Gigabit Router (TL-WDR3600) @ £59.99 inc VAT
Highlights:
•Simultaneous 2.4GHz 300Mbps and 5GHz 300Mbps connections for 600Mbps of total available bandwidth
•2*USB Ports - Easily share printers, files or media with your friends or family locally or over the internet
•Full gigabit ports ensure ultimate transfer speeds
•Achieves blazing WAN to LAN throughput of over 800Mbps with hardware NAT
Only £59.99 inc VAT.
ORDER NOW
TP-Link Dual Band N600 Concurrent Wireless Router (TL-WDR3500) @ £52.99 inc VAT
Highlights:
• Simultaneous 2.4GHz 300Mbps and 5GHz 300Mbps connections for 600Mbps of total available bandwidth
• 1 USB Port - Easily share printers, files or media with your friends or family locally or over the internet
• Wireless on/off switch- Green wireless lets you simply turn the wireless radio on or off
Only £52.99 inc VAT.
ORDER NOW
TP-Link Dual Band N900 Concurrent Gigabit Router (TL-WDR4900) @ £109.99 inc VAT
Highlights:
• Simultaneous 2.4GHz 450Mbps and 5GHz 450Mbps connections for 900Mbps of total available bandwidth
• Full gigabit ports ensure ultimate transfer speeds
• Achieves blazing WAN to LAN throughput of over 900Mbps with hardware NAT
• CPU Clock Speeds of up to 800MHz can handle more data much faster
• 3*5dBi external antennas and 3 internal antennas provide maximum wireless coverage and reliability
• Dual USB Ports - easily share printers, files or media with your friends or family locally or over the internet
Only £109.99 inc VAT.
ORDER NOW
TP-Link N600 Wireless Dual Band PCI Express Adapter (TL-WDN3800) @ £30.95 inc VAT
Highlights:
• Dual Band support - 2.4GHz or 5GHz channels bring an optimized HD video streaming, file sharing and online experience
• Wireless speeds of up to 300Mbps
• Two antennas increase wireless performance and stability
Only £30.95 inc VAT.
ORDER NOW
TP-Link Universal Wall-Plug Range Extender (TL-WA850RE) @ £34.99 inc VAT
Highlights:
• Range Extender mode boosts wireless signal to previously unreachable or hard-to-wire areas flawlessly
• Miniature size and wall-mounted design make it easy to deploy and move flexibly
• Easily expand wireless coverage at a push of Range Extender button
• Ethernet port allows the Extender to function as a wireless adapter to connect wired devices
Only £34.99 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless N Gigabit ADSL2+ Modem Router (TD-W8970) @ £52.99 inc VAT
Highlights:
• All-in-One Device: ADSL2+ Modem, NAT Router, 4-Gigabit-Port Switch and Wireless N Access Point
• 300Mbps Wireless speed and Gigabit Ethernet ports, ideal for multiple HD video streams
• Versatile Connectivity: ADSL or Ethernet WAN for multiple Internet connection types
• 2 USB ports for storage sharing, printer sharing, FTP Server and Media Server
ORDER NOW
TP-Link N600 Dual Band Wireless ADSL2+ Modem Router (TD-W8980) @ £81.98 inc VAT
Highlights:
Only £81.98 inc VAT.
ORDER NOW
TP-Link AV500+ Gigabit Powerline Homeplug Adapter with AC Pass Through (TL-PA551) @ £48.95 inc VAT
THIS PRODUCT IS A UK PLUG AND NOT EU PLUG AS THE IMAGES SUGGEST
Highlights:
• Integrated power socket to allow additional devices access to power
• HomePlug AV standard compliant, high-speed data transfer rates of up to 500Mbps
• No new wires, Easy Plug and Play operation, No configuration required
• Patented Power-Saving Mode automatically reduces power consumption by up to 85%*
Only £48.95 inc VAT.
ORDER NOW
TP-Link AV500+ Gigabit Powerline Homeplug Adapter with AC Pass Through, Twin Kit (TL-PA551KIT) @ £79.99 inc VAT
Highlights:
• Twin Pack design helps establish a basic powerline network
Only £79.99 inc VAT.
ORDER NOW
TP-Link 300Mbps Wireless N ADSL2+ Modem Router + USB port (TD-W8968) @ £39.95 inc VAT
Highlights:
• All-in-One Device: ADSL Modem, NAT Router, Switch and Wireless N Access Point
• 2.4GHz, IEEE802.11b/g/n, up to 300Mbps data transfer rates
• USB Port for Storage Sharing, Printer Sharing, 3G Modem* Sharing, FTP Server and Media Server
• Supports the latest Internet Protocol IPv6 to future-proof your network
• Ethernet WAN (EWAN) offers another broadband connectivity option for connecting to Cable, VDSL or Fiber modems
• IP QoS features for improved bandwidth control across the network
Only £39.95 inc VAT.
ORDER NOW
Hi there
These look rather up market, TP link aiming for a bit more of the higher end of the market?
Love the plug straight in extender. Had a client recently who was annoyed at having to have another big box in the house, these will be perfect :)
Hi there
definitely, they have all areas of the market covered now.
The AC passthrough plugs looks excellent.
they are
the 200mbps kit is brilliant and easily the most popular networking sku we run with, but this is not only an evolution but passthrough makes it an even more attractive prospect.
my brother actually has one of these which is what prompted me to buy it in.
very nice bit of kit and useful too
Do the UK Homeplugs have the plug at the bottom of the unit or at the top, like the EU plug? My plugs are too close to the floor/skirting board otherwise :(
At the top, Kelt.
I've got the 200Mbps ones (along with a regular TP-Link 200Mbps one), they've been flawless so far.
At the top, Kelt.
Thanks. Don't know why most of these seem to be designed this way. Oh well, on with the cat5 cabling plan!
Does anybody know if the powerline adapters work with BT Infinity?
I heard a rumour that BT have somehow stopped them from being used.
naw they still supply them with YouView boxes and BT Vision boxes. Only way they let you have Sky Sports now is if you are on BT Infinity, so if you order BT Vision (YouView cant accomodate Sky Sports yet - bad foopah) and Sky Sports, you have to be on BT Infinity then you also get the option to have the free powerline adaptors.
In any case powerline adaptors are nothing to do with whether BT Infinity works or not. They are just used for the network in your house doesnt matter what you use after the modem. You can use the HH3, or just about any router so I can't see them coming up with a way of stopping powerline adaptors from working.
Yep, as far as the router is concerned, the powerline adapter is just a network cable; it's the device that it's connected to at the other end that it'll identify, nothing more.
I take it they are like photo and not uk plugs?
I need a range extender, that one looks nice and simple, apart from the plug situation.
oh, well apparently i didnt check all the images. the others say they are a uk plug so i assume this one would be too.
It'd be rather silly for a UK company to be selling products without a UK plug on them, no?
Off course,but it doesn't explicitly say uk plug, why use wrong pictures.
Wouldn't be the first time a company used cheap eu products and put an adapter in. I'm sure could dont do this, it's mainly a complaint about the pictures used and lack of clarification.
It's just lazy using wrong pictures and despite the for illustration purposes only warning, most people shop with their eyes first, a picture is worth a thousand words after all.
