Heaven is not that CPU intensive, i can't see it making that much difference, gregster, tho i will concede i'm really struggling to understand what going on here, you may well be dead right...
We can take this in to the CPU room and try that, but first...
@ rabc, assuming you did not touch any of the settings in Heaven, ran it as is, which is what i just did at the same GPU settings as you, and well, i more than doubled your score on a lesser GPU, you should be getting more than me.
I'm looking at the 5800K's iGPU and thinking, "is that whats actually running?" but the score, i think is to high for it.
Can you disable the iGPU in the BIOS?
Check the tessellation it appears to be disabled.
There is no 4x AA Either.
just noticed u ran your without 4xAA or tessalation i shall run again with those settings
