Permabanned
- 8 Jan 2010
- UK
If you're using a waterblock then get the non reference ones. Can someone confirm if the reference ones are voltage locked and the non reference ones are fine?
As you're using waterblocks I'd say go for this:
http://www.overclockers.co.uk/showproduct.php?prodid=gx-049-hs
or even this for £10 more as you get better warranty:
http://www.overclockers.co.uk/showproduct.php?prodid=gx-098-gi&groupid=701&catid=56&subcat=1673
(you need to check though if water cooling doesn't invalidate the warranty, but then how will they ever know?)
http://www.tomshardware.com/reviews/radeon-hd-7950-review-benchmark,3207-13.html
