*** Images of Items or Services Purchased in February 2013 ***
I don't do either of those so it's above adequate for my needs. Those parts may be fine for his needs but I was just pointing out they're bad, the monitor has high input lag and the GPU isn't worth the price/performance compared to a 7850.
You're contradicting yourself... How do you know what his needs are to say that those parts are 'bad'? :-/
Edit: clearly has now been addressed above that you were being a ****. Next please.
I was stating they were bad parts in my opinion for my needs. Should have explained myself better.
Thread is off topic. Here's something I bought which befits my views on small change:
Yeah i know, im not ready as of yet to fork out £50 for a sdxc one, i've had cheap ones before that have lasted a fair while.
Showing as 62.2GB, all good so far. Holding out hope.
Should show as 59.46GB I think shouldn't it?
Also try filling it right up - then you'll know if you have the full capacity for sure and not something like 16GB.
36quid for a 64GB class10 sandisk one at the moment.
I'd settle for a monitor that worked.
Changed VGA cable as it was bust and giving a pink screen.
Now not one single resolution fits the screen, but it's not pink at least.
Press the AUTO button on the monitor.
Just got a New 1080P projector powered by a Mac Mini to watch films while working (gaming). Uni Digs suck... TV just slightly in the way.
My Main Desk and Setup
My small sum of purchases, curse the little plastic bags, granted the contents are on the side in bits waiting to be glued and painted.
Kimbie
