Duplicate 'My Documents' on other drive.. Delete files and they delete from the other drive?!
8 Feb 2011
Colchester
I just noticed something really odd while trying to clear up a drive. I have a user folder on this drive with a 'My Documents' folder inside it. I thought it was an old backup but upon opening 'My Documents' on my C:/ drive its identical. I deleted a file from the folder on my other drive and it also disappeared from the C:/'s folder.
Whats going on? I can't delete this user folder on my other drive because it will delete my C:/ ones.. I was hoping to format it :|
This seems like an odd issue and I can't imagine what would cause it.
Any ideas?
idk,maybe if its shared? or linked?
look in permissions
What should I look for in permissions?
I should add, this is an external drive in an enclosure I only plugged in today for first time in a few weeks :|. The folders i'm speaking off are ghosted like hidden folders with a little padlock on them.
try renaming the folder on your external drive,and see if it affects your c drive/documents when you delete a file
Renamed the user folder to user1 and documents to documents1. Still deletes both files if I delete one. I guess its not a copy but actually the same folder somehow being beamed into the other drives folders magically for some weird reason. I don't think the user folders take up any extra space on the external drive so they aren't really there :|
i think you can exclude it from your library,i think its sharing the two folders as one,but i forget now how you do it
This is what its properties window looks like..
Uploaded with ImageShack.us
I'm going to plug the drive into another computer. I'm sure the folders contents will disappear but I wonder if the folder will aswell.
I realised I haven't even tried to delete the folder yet.. Suppose i'm scared i'll delete the main one like the contents!
Edit: lol. Deleting it got rid of it.. and didn't remove the main folder... Sorted I guess but still no explanation?
"My Documents" is a special folder that always reflects whats inside the local user document folder usually c:\Users\<username>\Documents you can add or remove folders from that collective (the contents of which will be displayed from any "My Documents" special folder).
