It just depends what the user needs from their htpc. I use Virgin so have no need for a tuner card, whereas others may like just having freeview in which case they user their htpc as a pvr.
You have Virgin as your TV supplier is that it? Why don´t you need a tuner card then, can you elaborate a little more please?
What does pvr mean? Sorry, I´m from Portugal...
Edit: Personal Video Recorder. It means that you have a box from Virgin that already allows you to record your stuff right?
So the tv cards only allow you to record right?
Lurkio, why did you put 2 tv cards and different ones on the build?
the 6220 , get you freeview HD/SD channels ( from ground based transmitter)
the 6981, gets you HD/SD channels from a satellite (based in space, same one sky transmitts from)
The reason I have both freeview and freesat is that there are channels that are only
on one of the services (tho there are a lot that are transmitted on both)
The tv cards allow you to watch / pause / record live TV and also to stream tv channels
to any other pc in the house that has the media portal client installed onto
Even with a single tuner card you could watch one channel and record 4 other channels IF they are on the same MUX
It depends in the uk, we have bbc iplayer, 4od etc
So with a web browser you could watch live or catch up tv using those services
I've got one with Windows 8 and xbmc on it. Works fine although does struggle a little with the more advanced skins.
(Also no option to include a BR drive, without buying the model which comes with one)
