Windows 8 Pro BSOD help!
Been testing this out more today...
Prime95 Blend test - 4 hours passed without error with settings:
Set-up 1: BIOS Optimized Defaults
i5 @ 3.4Ghz - Completely Stock (stock voltages (everything at auto in BIOS))
RAM @ 667Mhz 9-9-9-24 1.5v
So I'm pretty happy that so long as the RAM is under-clocked to 667Mhz and running at 1.5v, things will be pretty stable. I then tried the below set-up:
Set-up 2: Slight Multiplier OC
i5 @ 4.0Ghz (40x100BLCK with stock voltages)
The above Blue Screened after about 30 seconds into the Prime95 Blend test. Can this still be attributed to the RAM, even though nothing RAM related changed between set-up 1 and set-up 2??? RAM was running at the exact same speeds/voltages for both set-ups...it was only the CPU multiplier changed between the two, yet set-up 2 insta-crashed...
It could be you Overclocking the CPU without adding more voltage to it.
OK if I leave the memory settings alone and focus just on the CPU, what would you recommend for a modest 4.0Ghz?
100BLCK X 40
Voltage Response to Fast
CPU Vcore @ ???
OH MY ******* GOD! That set-up, which did 4 hours in Prime without an error, that I've been using all day to play PoE and Blops 2, just gave me the same f'ing error WHEA_UNCORRECTABLE_ERROR about 1 minute ago...
So I don't even think it is memory voltage related anymore...I'm getting fed up with this!!!!!!!!!!!!!!!! What else could it possibly be??
I would run your ram at 1.55v for 1600mhz,you can set system performance enhance to standard if your on a gigabyte board,and try looser timings of 9-9-9-28-2t
Whea error is not enough CPU voltage,
Edit,you can be 100% stable with CPU stress but soon as you start gaming it will throw up whea errors so you have to up CPU v some more
I'm running it at 1.5v @ 1333Mhz just to keep the PC from crashing every few minutes. I will try going back to 1600mhz with a reduced voltage of 1.55v, however the manufacturer recommends 1.65v for that speed, so I don't think it will be stable!
But what I don't understand is how the CPU can not be getting enough voltage; it is at factory settings?? The lowest I'm seeing in HWMonitor is 1.092 and the highest is 1.260. Surely the chip wouldn't ship with such an issue?
What would you suggest I up the Vcore to?
Hi Chris, seems you are not having much luck at the moment. Can`t offer any info that will help solve your issues, other than suggest you open a thread in the link below. No disrespect to shankly or wazza who have been very helpful but the Overclocking forum would be a more informative place for help then a software forum.
Any way, I wish you good luck and hope you get things sorted sooner rather than later.
http://forums.overclockers.co.uk/forumdisplay.php?f=149
Thanks Idleman. I have posted in the Ask 8 Pack sub-forum, is that correct?
