Corsair H100i backplate.
You either tried the AMD backplate originally or you did not realise that on the Intel plate that the holes in the corners are adjustable? :D
Liam
Liam
H100i doesn't come with an AMD backplate. It uses the standard fit AMD backplate.
At a guess, looking at the Intel backplate, either:
1. As Castiel suggests, you didn't adjust the backplate correctly
2. You tried to use the AMD block bracket instead of the Intel block bracket.
