9 Feb 2013 at 16:08 #1 Danthus Danthus Permabanned Joined 5 Jun 2010 Posts 15,459 The Intel backplate does not align with my MSI P67 GD53 board. Are there two backplates ini the box or am I being stupid?
9 Feb 2013 at 16:24 #2 Danthus Danthus Permabanned OP Joined 5 Jun 2010 Posts 15,459 I was being thick Anyone care to guess what I did wrong?
9 Feb 2013 at 17:19 #3 LEK-89 LEK-89 Associate Joined 11 Oct 2008 Posts 2,240 Location Leicester You either tried the AMD backplate originally or you did not realise that on the Intel plate that the holes in the corners are adjustable? Liam
9 Feb 2013 at 17:45 #4 Castiel Castiel Permabanned Joined 26 Jun 2010 Posts 0 OldCoals said: I was being thick Anyone care to guess what I did wrong? Click to expand... You didn't realise the backplate is adjustable?
9 Feb 2013 at 18:22 #5 Resident Resident Soldato Joined 10 Mar 2012 Posts 3,913 Location unstated.assortment.union LEK-89 said: You either tried the AMD backplate originally or you did not realise that on the Intel plate that the holes in the corners are adjustable? Liam Click to expand... H100i doesn't come with an AMD backplate. It uses the standard fit AMD backplate. At a guess, looking at the Intel backplate, either: 1. As Castiel suggests, you didn't adjust the backplate correctly 2. You tried to use the AMD block bracket instead of the Intel block bracket.
