My car feels as flat as pancake on 95 ron. Put a tank of 99 ron in, and within a few miles the timing has shifted forward and the top end power is much better, and mpg goes up a little too.
Mine runs absolutely fine on 95, I would expect it to be pickier being a higher state of tune.
Surely all modern mass produced cars are built to within such a massive margain of error that they'll run on any fuel, with regular UK 95 Ron being at the higher end fuel spectrum?
However, not sure why you can't get hold of Super, every BP garage I go to has it, Shell has VPower (which I only use in the RX8)... not sure why you have a problem. You live out in the sticks?
I scanned through it and didn't see a reference as to why. Christ almighty, usual forum **** again. Bye.Would it really be so difficult to just read the thread?
The 1.8t 240/225ps versions have quite high compression, so they need a higher ron fuel to avoid pinking. If they are run on 95, the timing is reduced to avoid pinking, so you won't get the full potential out of it, but it will run just fine.
I'd be interested to see what the power difference actually is. I'd be amazed if it was more than a few bhups. Didn't 5th gear do a test a few years ago and it was about 5bhp on a mk5 GTI?
Think the reference was in the OP... which has since been deleted. Helpful ey??![]()
My HONDA bike has a compression ratio of 12.1... which is far and away higher than yours and SUL makes absolutely no difference at all, same as my car, which suggests 98ron on the fuel cap, it makes no difference. If your car is smoother on SUL then it's most likely predetonating on 95 and is going to blow up.
Because the knock sensor can detect more than knock
