i got 16gb ram now in the microserver, its now caching lots more
Which Microserver?
Good afternoon,
So i've got my server all built and set up, build log here:
http://forums.overclockers.co.uk/showthread.php?t=18486228
If I do a large file transfer between HTPC / N40L, I only appear to get about 12MB/s transfer speeds. I'm using WD Red drives in a RaidZ array, does anyone else think that's a little on the slow side? I would have expected to see at the very least ~60MB/s transfer speeds?
Everything's wired on a Gigabit NetGear 105 switch...
have you enabled passthrough in the BIOS?
The only settings i've changed are:
From the MAIN Screen I went to => Chipset Menu => Southbridge Configuration => SB SATA Configuration => and set the following:
- OnChip SATA Channel [Enabled]
- OnChip IDE Type [IDE or Legacy IDE](1)
- SATA IDE Combined Mode [Disabled] — sets Ports 4 & 5 to use AHCI
- SATA EPS on all PORT [Enabled](2) — sets all Ports to be external SATA Ports
- SATA Power on all PORT [Enabled]
Where would I find this passthrough setting, what does changing this setting do out of interest? I'm not familiar with it...
Thanks for your response!
Ah sorry I was getting mixed up. It was write caching I think?
I think I'm right in that I can't talk about competitors shops here directly, but, if you Google for n40l Servers, you should be Directly on the right track.
so is there any 'particular' one to buy. I have noticed some with more memory etc.
Which one is best for me to look at and order then.
Just was not sure if it would be suitable to run Windows 7 (32 or 64??) for basic office work.
Good afternoon,
