Lost 6 in a row for my Bristol Rovers team, any tips on league two formations ?
I've got David Suazo/Junior Agogo/Nicolas Bignall( loan from reading ) as my 3 strikers and i rotate them.
4-4-2, direct, fast tempo. Quite wide at home, narrower away. Hard tackling, high pressing. Rigid philosophy.
Centre backs: Limited Defenders; set your fastest one on Cover duty. Set both to be Defensive/Ultra Defensive mentality and no creative freedom.
Central midfield: Ball-Winning Midfielder [Support if he can pass, Defend if he can't]. Team him up with an Advanced Playmaker, one of the few players you can give a bit of creative freedom to. BWM is crucial: needs to be strong, determined, fast and have good tackling and positional awareness. A good BWM will quickly become your cult hero
Wingers: Cross from Byline. Train Player Preferred Moves - Hug touchline, knock ball past opponent, get forward often, run down left/right. Keep them wide in Wide Play.
Up top: One AF or Poacher, one DLF or Target Man, if you've got a strong tall one good at headers. Run into channels from Wide Play. Neither should have as much of an Attacking mentality as you may think, as they don't have the Finishing/Composure to be that attacking at that level [if you're getting Clear Cut Chances but not converting them, this is a prime suspect]. Pace and Acceleration important for Poacher/AF, obviously.
Set pieces: really spend some time with the Set Piece creator, as it can reap huge dividends. Got a tall, fast player with good Anticipation, Jumping and Heading? Get him to attack near post at corners, and make sure corner takers are aiming at the near post or 6-yard box with inswinging corners [so your right-footed corner taker takes corners over on the left side of the pitch, and vice-versa].
I should point out that this is all stuff I've learned from FM2012, but the match engine hasn't changed very much from what I can gather, and the principles are all sensible.
HTH
