I take it that picture isnt of the local lad in question cos that's Brendan Fairclough. Seen that stepdown pop up on the net a few times. Looks cool if a bit daunting
So I've got a couple of rather retarded questions incoming.. Like always
What will the steerer be on my forks? I see all different sizes and stuff, but no idea to tell which is which :S
Second, if you buy a frame, does it come with a BB preinstalled, or do you have to buy that afterwards? I did say they were retarded, but I gotta learn.
Steerer is most likely 1-1/8" from the picture, but it could be a tapered steerer, 1.5" - 1-1/8" bottom to top. Frames don't normally come with a bottom bracket, cranksets come with a bottom bracket usually.
Well yes and no. Some frames will only take a certain type of headset, nevermind the size. Best thing to do is find your frame, then look at compatible components. Just like buying a motherboard and finding compatible ram, CPU etc..
Most frames follow the standardised headset identification system (S.H.I.S) now so it's easier to find what'll work. The easiest way is to use cane creek's headset finder to identify the right top and bottom cup for your frame.
Can only find info on the 2012 version but looks like it is a full 1.5" head tube with an integrated headset, so dependent on the headset fitted will be able to take any steerer width.
We've got a Giant dealership local to us, and we're off to look at a Revel 29er 0 tomorrow morning, but the spec looks a little meh, can anyone recommend something suitable please?
Just got a wheel built by Superstar. Wheel turned up two days after ordering it which is good I guess, shame the build is awful. There's literally no tension to the spokes, the thing would just fall to bits if ridden on anything other than tarmac!
I'm getting another wheel built up by Just Riding Along, I let them have a look at the Superstar wheel whilst I was there and they just laughed at it....
