Are you offering kind sir ?![]()
I wouldn't want to take it away from gregster, he's our resident benching thread guru
Gigabyte 7870 @ 1175Mhz / 1450Mhz
Extreme
High
Here's mine. Loaded it up selected Extreme profile and left all other settings to default.
Can we establish a common set of settings to use
I found using the Extreme Preset had a problem recognizing xfire on my AMD cards and I was only getting a score for one card.
I found it better to use
Mode = 1920*1080 8*AA Fullscreen
Preset = Custom
Quality = Ultra
Tessellation = Extreme
With this xfire was working ok.
Anyone compared how well their computer handles this version compared to 3.0 by using equivalent settings to match the criteria of the Heaven 3.0 thread?
I wouldn't want to take it away from gregster, he's our resident benching thread guru![]()
Please feel free to jump in (or anybody for that matter). The slating I got in the 3DMark thread has put me off doing benchmark threads.![]()
who slated you? (they should be banned!!), your tables are the best, fun and painless the way they should be, as always great work gregster, not like the heaven one thats just a PIA
How are you guys forcing fullscreen ?
I cant get it to work "in bench" or from the main option screen![]()
