Well, being the house decorator, i might be able to help
First off it is hard to tell how bad the bubbles are in that pic, but if you're going to roll the walls, you'll end up getting a rollered effect anyway, so you might not notice them? But if you're that worried about them, then give the walls a wee sand down.
no need for mist coats, you're not painting over bare plaster, 2 good coats of any matt paint should do.
