Meh, is there actually any difference considering they've been released within like a week of each other?
Thanks for the help
One question though, if I install this firmware then they release the official one later, can I just load up kies and install it? Or do I have to then uninstall everything.
Download the usb drivers for your phone here first.
http://forum.xda-developers.com/showthread.php?t=1655286
When you have done that, turn the phone off, boot into download mode (volume down, home and power key at the same time), open Odin, plug in the usb cable and two (i think) boxes at the top should go yellow saying "COM 1" or something similar. When that has happened, just follow the instructions from the link i posted in post 23.
You have the same model of Galaxy S2 as I do OP.
The GT-I9100P which is the same as a GT-I9100, except it has NFC built into it!
I flashed the Nordic Version of Jelly Bean onto mine yesterday, I've lost the NFC capability. But I'll never use it anyway!
You have to flash the phone using Odin, which is risky if anything goes wrong.
But you'll be waiting a long long time for O2 to actually release their version of Jelly Bean for the NFC S2.
It took them ages to release Ice Cream Sandwich onto it!
Anyone that has flashed the nordic version having trouble with wifi tethering? I'm on orange/ee network and it no longer lets me tether my ipod![]()
Hi, I'm thinking of doing this flash with odin i understand the flashing process ok but:
1) would it be ok on a locked three mobile s2
2)would i loose all my contacts & apps
jellybean does look good
Thethering doesn't yet work on all JB roms
Never heard that mentioned?
Is it not the apple products can't connect to Android. Only ever tried one I phone and it didn't work
