- 20 Aug 2007
What's the best way to do this? In the past I've normally just done a 7 pass erase on a standard HDD before selling. But when it comes to a SSD I'm not so sure.
SSDs only need 1 pass to securely erase.
That's a load of ********. It is easier to recover from SSD's than Modern HDD's. Read some papers on it then see if you still believe that statement.
Source? As you're wrong.
OP unless you're hiding some seriously dodgy material a single pass of zero's will suffice.
Hell no. Secure Erase takes seconds where as zeroing takes a while, doesn't guarantee data elimination & does tax the drive.
