*** The Official Google Nexus 7 Thread ***
Got mine yesterday and is brilliant!
I'll root it when the 4.2.2 update is sorted out.
I'm going to get a dock when they come back out. Pogo charging so I don't have to use the cable. It's just the dock though no cables.
I rooted first on 4.2.1 using one of the toolkits, installed CWM, then updated and once I was on 4.2.2 CWM asked me if I wanted to "fix root" which worked!!
Still rooted and running 4.2.2 :cool:
Iv never rooted anything in my life and dont understand a lot of it and im very very scared il brake my new shiny toy. So im going to wait it till it can be done as pain free as possible. :p and besides im allready on 4.2.2
I want to root my s3 aswell but atm its my internet connection so i think il wait till i can root the nexus and see how well that turns out before moving onto what essentialy holds my life and not easily replacable due to being a student.
Hi all.
Is there an easy way to transfer a file larger than 4GB file to my Nexus? the Android Tile Transfer App won't go over 4Gb in size.
How does googleplay handle faulty returns.
Am not being picky this time but when ever my youngest N7 runs flat I have to play around with the power button for 30 secs with the charger plugged into to try and get it to charge. does not always work.
The other one charges straight away
How long does it take to charge the nexus 7 while it's on but not in use?
Mine was taking 12 hours for 70% so i swapped the battery with a broken one I've got and now it's take 1 hr 50 mins for 50% which seems like what it used to be.
Anyone else had this issue?
Tried a few charger's, don't know where the original one is now you have mentioned it ha.
Think the battery has lost life because my son uses it every day nearly and it's killed, it did hold it's charge fine and lasted about 5 hours constant hammer
